Go Back   FourWheelForum > Truck Talk > Tire & Suspension Talk
Tire & Suspension Talk The most important handling aspect of every vehicle...
Unread 03-05-2013, 01:14 PM
digglah digglah is offline
Junior Member
Default Broken Sway Bar Link Mount - 98 5.9 ZJ
Must have snapped from the stress turning into this steep angle in my driveway every day.
Unread 03-05-2013, 01:52 PM
Junior Member
Pretty sure having a stiffer addco swaybar just put too much torque on that flimsy little mount. That angle iron L-Bracket should probably be eliminated somehow, so it can just be attached with a straight-through bolt.
Some axle mounts like this would probably be the way to go:
http://www.rustysoffroad.com/rustys-...unts-pair.html
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
